Cams
Hi
I’ve been a member for a while but this is my first post as i need some help. I have a vf1000f that needs cams and they are rare to say the least so i am wondering if a full set of vf750 cams will fit as they are more readily available. I would think that the lift or timing may be slightly different but does any one know if they will fit and run.
Hi the 750 cams don’t fit journal length is different and cam width is different plus other things your best bet is to have your cams re profiled like vf Pete as done, and also check your rockers as they wear as well if engine as been neglected in the past
