Carb joint o rings
Can someone let me know what the VF1000R carb joints o ring size is? All look the same size for plastic and aluminium joints.
Thanks
Fuel Feed joint o-rings are 8mm (inside diam.) x 2mm thick.
Air Vent joint o-rings are 7mm (inside diam.) x 1mm thick
First class info,thank you for letting us know
