I’m struggling to align the clutch basket onto the oil pump Drive sprocket, it seems like the clutch won’t go back far enough. The crank teeth and clutch teeth won’t fully slide together, any ideas am I missing something. Thanks
Hi, the clutch sprocket is split and spring loaded, slide it half way on then use a screwdriver in the teeth to align the half , making sure the oil pump sprocket pins line up with the indents in the back of the clutch…
P.s, I’m assuming that’s the clutch that came off there, the f2 boldor clutch baskets and primary drive sprocket are different to the fe and ff models
