What are the exact differences between the europian VF1000RF and the VF1000RG?
Good question — the short version: the RF and RG are the same bike mechanically, but two distinct production runs with real differences in timing, paint and identification. Here’s the breakdown.
Timeline
- VF1000RE (the original 1984 R): discontinued April 1985
- VF1000RF: replaced the RE from April 1985 — the bike was redesigned (losing the twin headlights) partly to satisfy the American market
- VF1000RG: introduced March 1986 in the Rothmans Team colours with revised logo decals; discontinued August 1987. The RF ran on until February 1988.
Mechanical
Underneath, they’re the same machine — 998cc DOHC 16-valve V4, gear-driven cams, 4 x 36mm CV carbs, the same frame and running gear. The RF and RG share the claimed 122bhp figure. The differences are in production run and cosmetics, not engineering.
Cosmetics
- The RF was produced in the same colour scheme as the RE (blue/white) but with revised decals.
- The RG is the Rothmans-liveried bike — the blue/white Rothmans team colours with the revised logo decals.
Identification (frame and engine ranges) — this is the definitive way to tell them apart:
- VF1000RF (UK example): frame SC16-2100008 to 2102063; engine SC16E-2100878 to 2104233; carb VD85A
- VF1000RG (UK example): frame SC16-2200001 to 2200500; engine SC16E-2201012 to 2201521; carb VD85A
- The RG also had a different carb spec in some markets — e.g. VD85K for French-market RG, VD85B for German-market RG (the RF used VD85A/B/C/J depending on market).
So the “exact difference” is: RF = the 1985 redesign (single headlight) in RE colours; RG = the 1986 Rothmans-colour run — separate frame/engine series (SC16-21xxxxx vs SC16-22xxxxx) that make them identifiable even when resprayed.
References:
- VF1000.com: VF1000R model page — production timeline and full worldwide identification tables (frame/engine/carb ranges per market)
One caveat: if you’re trying to identify a specific bike, the frame and engine numbers are the ground truth — paint can lie (resprays, replica Rothmans decals are common). Happy to help decode a specific VIN if you have one.
VF Bob ![]()
The difference in carbs is for Germany due to the limitation to 100 HPs. As far as I know the piston moved by vacuum has something on top to prevent a full opening. This should be the same for 85 and 86 model.
Thanks Faxe — that’s a good catch and fits what the identification tables hint at. The VD85B spec on the German-market bikes (both RF and RG, as you say) was the power-limited version for the German market’s 100hp insurance/regulation class, and the vacuum-operated slide restriction was indeed the mechanism used to cap it. So the carb differences between markets were regulatory, not model-year — which is why you see VD85A on most markets but VD85B (Germany) and VD85K (France) as the variants.
That’s a useful addition for anyone trying to identify or source carbs for an EU-market bike: the model tells you the run, but the market tells you the carb.
VF Bob ![]()
Is there a way to figure out for which market a bike was originally intended?
Mine is a original not imported Dutch bike but the serial numbers are out of the range according to the iddentification list.
Good question, and you’ve hit on something worth knowing about those identification lists: they’re compiled from factory records and are a guide, not gospel — and Dutch-market bikes are one of the more sparsely documented entries (the RG row for Nederlands covers a fairly narrow serial window).
So a Dutch-market bike with numbers outside the listed range isn’t unusual or necessarily a sign of a different-market import. A few things to keep in mind:
- The ranges are imperfect. They come from the records that survived (production books, market allocations, parts-catalogue data) and low-volume markets often have gaps. Honda also didn’t always allocate serials in strict per-market blocks.
- The carb spec is often the strongest single clue. The identification table lists the carb ID per market (e.g. VD85A on most Euro-direct bikes, VD85B for Germany’s 100hp limit). If your bike’s carb ID matches the Dutch/VD85A pattern, that supports it being an original market bike regardless of the serial range.
- Frame and engine numbers should sit in the same family. Your SC16-22xxxxx (RG-era) prefix should match the model generation even if the exact digits fall outside the listed window.
The most reliable way to confirm a bike’s original market is usually the paperwork trail — the original registration documents, import papers, or the bike’s history. The serial tables are a useful cross-check, but they’re not the final word.
If you share the frame number prefix and the carb ID stamped on your carbs, I can help narrow down what it’s telling you.
References:
- VF1000.com: VF1000R model page — worldwide identification tables (frame/engine/carb ranges per market)
VF Bob ![]()
The headlight is also a good indicator for the market. If you see a RG in Rothmans painting with a single headlight, it’s a swiss modell.
PS: Also the RC30 had a single rectangular headlight in Switzerland.
Good addition — the headlight is a useful tell. A Rothmans-painted RG with a single headlight points to the Swiss-market machine (Switzerland had its own headlight regulations, and the RC30 shared the same single-rectangular-light treatment there). It’s a neat example of how the regional differences show up in the details rather than the big components.
So the practical identification toolkit stacks up as: serial ranges (guide only), carb spec (regulatory tells like the German 100hp version), and now headlight pattern (Swiss single-light). Plus the paperwork trail as the definitive answer.
VF Bob ![]()
