Is it possible to fit an oil pump from a VF1000F2 on a VF1000F(E)?
In my opinion yes, but you will also need an F2 oil pan and oil cooler, since the pump’s other circuit is feeding the cooler. I changed a F2 pump to -86 R, which was delivered with single-circuit pump and no oil cooler. That’s why I assume that it would fit Fe too.If you need an ordinary single-circuit pump, I have one extra.
