Wanted ignition control unit for FE, the white connector one that runs the rear cylinders and Rev counter. Thanks
If the fault is intermittent it can usually be repaired if you are competent with a soldering iron, if you’re not then I can try to repair it for you as I’ve done several before. The only problem is I don’t use the standard ignition on my bike so can’t test if it works ok.
I managed to find one on eBay which I’m going to try, if it’s works then great but if it doesn’t it would be much appreciated if you could have a go at repairing mine. Thanks for reply I could be back in touch
