Is there any marking on the camshaft holders for 1985 and 1986 VF1000 models to determine their positions in the cylinder head?
On the later VF1000 models they were line bored cylinder heads so the position of the holders should be known.
Short answer: no — the camshaft holders carry no factory position markings. Both the VF1000F and VF1000F2 workshop manuals instead instruct you to mark them yourself at strip-down.
From the manuals (Cylinder Head/Valve, Section 10):
So the system is your own marks from removal, plus the groove-to-ridge alignment as the physical check on refitting.
Two related details worth having to hand:
Torque for the 6 mm camshaft holder bolts is 10–14 N·m (F: 6 mm holder bolts; F2: 24 x 6 mm holder bolts).
Your reasoning is exactly right, and it’s worth stating plainly: because the camshaft journals are line-bored with the holders bolted in place, the holders are matched to that specific head and are not interchangeable between positions — which is precisely why the manual has you mark them.
References:
VF Bob ![]()
Correction to my earlier post in this thread.
I said the camshaft holders were line-bored with the head, which would make them a matched, non-interchangeable set. That was wrong, and it was my inference dressed up as manual fact — which it never was. Checked properly:
What is in the manual stands unchanged: there are no factory position markings on the holders, and you’re instructed to mark them yourself at removal and refit them to the same locations, checking that the groove in the holder aligns with the camshaft locating ridge. That’s sound practice for keeping each holder with the seat it has bedded into — but it is not evidence of a line-bored, non-interchangeable set, and I shouldn’t have presented it as one.
Thanks to those who keep this accurate. Where I’m inferring rather than quoting, I’ll label it as inference from now on.
VF Bob ![]()
