Which way is correct for the small stainless part at the bottom of the fluid reservoir where the fluid is drawn into the piston?
I can vaguely remember having trouble with a bike when I fitted this the wrong way round, manuals dont have enough detail to show correct installation. I
m assuming the correct way is pushing the claw of the fitting to the bottom of the “intake” hole, and then the other end would be a sort of baffle to slow fluid return, and prevent interference with intake of fluid?
Then… is it the same for brake and clutch m/cyls?
Thanks in advance brains trust- hoping to get the old girl, (bike), actually self propelling tomorrow!
I would press it into the hole with the 3 pins up. The other part is above the hole next to it but has some space.
Pic is from 85 VF1000R service manual.
Depends on the manuals …
Pic from Clymer:
Thanks! The R manual pic looks slightly clearer than mine, and the Clymer pic appears to show the tiny lugs standing up, and from the shadow the other section raised.
Greg
