NO SPARK ON REAR CYLINDERS
VF1000R Bike starts and runs but only on front 2
cylinders. Checked pulse generators 470 ohms ea. Could the culprit be my kill switch?? only turns over when kill switch set to
run? should turn over either position?
Hi Ari,The ignition system is split into two,the spark unit with the red coupler supplies the front two cylinders,the unit with the white coupler the rear two.The rear unit also supplies the rev counter so if the rev counter isnt working it would suggest the unit is US.If the rev counter is ok try swapping the coils over and see if the problem moves.I am assuming you have an RE model.
Regards BIF
