[:)]Could anyone please tell Me where these two black pipes connect to.
Found them like this when I lifted the tank off
I going through the bike ready for next year recently purchased but I want everything correct.
My brother thinks they should be connected to the air box somewhere
he says …They appear to be diaphram atmospheric hoses these are normally attached to either the emissions system )drip back valve ect or go to two pipes that come out of the air filter
Any help would be appreciated[?]
photo link below
http://yfrog.com/n8cimg0802j
in the parts listing its labeled
JOINT SET FUEL D ?
They push fit into the large alloy airbox base once it is fitted over the carbs, and they should have small rubber o-rings where they fit into it. You should see 2 holes under the airbox base that align with these pipes.
thanks
Because I took off just the alloy part of the box I could not see how it connected
Thankyou again
Lloyd in Norwich
If you plan to remove the carbs, bolt the airbox back first. Otherwise fuel pipes between carbs will probably break when you pry them away. The carbs are quite keen to stay where they are, no matter if they are in or out.
