rebuilt carbs and clean inside but now no fuel pumping getting to carbs
Float bowls not cold, had a leaking t piece on the left side due leaking o ring seals seals
Tested pump on bench and it pumps perfect
tried the wire trick but no change
Maybe a fuse will check this afternoon
Update
refitted the pump but no fuel
found out why If you fit a straight bit of petrol pipe to the pump and original fuel filter don’t push the filter into the holder provided as it bends the pipe and stops the pump from working.
Leak fixed and running sweeeeeeet :slight_smile:
