Seal for fuel cap
Yes it’s quite easy to replace, if you search the site there is a tutorial on how to do it. Basically you buy a cheap Chinese fuel cap and remove the seal and replace the o ring in the locking mechanism.
Garyb
Hi Gary,
Just following on from your experiences with the VF fuel cap and seal replacement. With the seal and the gold retaining ring out would you be able to access and disassemble the rest of the cap?
The reason I ask is this… The top of my original cap is in poor condition, the black chrome is pitted and has shallow dents in.
I have another VF cap which has a really nice condition top. If possible I’d like to fit the original locking mech into the nicer condition outer. Hope that makes sense…
Ps. Do you have any left over Chinese rubber seals?
Many thanks and kind regards
Andy
I don’t think I have any left, will look tomorrow and let you know or post a link to the caps I purchased. I think Vfpete was talking about taking caps apart and that you can remove the outer skin and take the lock out. I know you can’t get at the lock from underneath so it stands to reason that you must do it from the top.
Thank you, that’s helpful…
I did try and peel the outer off of an old cap I had but it felt as though it would cause too much damage in doing so…
The hardest part or removing the outer is removing the sliding escutcheon, I snapped mine because I didn’t have the correct tool, you need something like car trim removers so it puls it out straight, once that’s out you can peel the black chrome outer off, it’s only crimped on, the lock barrel will practically fall out then… for people with caps that are locked shut on a tank, below the lock barrel is a slot, just turn it with a slotted screw driver and it will open…
Thanks Pete,
So the rotating/sliding lock cover on top pulls directly up and out?
After you re assembled did the outer cover fit snugly back on the inner body?
Hi, I only have one left and need that one but I think these are the same.
The person I got mine off is no longer trading on Ebay but these appear to be the same cap and also from China though postage was pretty quick. I thought it was vfpete who had said how to strip cap though it was on our VF1000.com Welsh weekend ride out and by that time on Friday night everything blurred into one so it could have been anyone!
Hi, yes it fitted back nicley
They did increase the price … When I bought them, they were less than half.
Yes, when I bought them they were £6 / €8 each.
It will not solve this and there is no other seal :roll_eyes:
There is a “one-way” air valve as far as I remember. To let air into the tank.
Dismantling the cheap chinese cap to release the rubber seal and fit it to the original cap worked twice for me Faxe, instructions on this site above by Gazb.
The one way valve is accessible from the underside of the cap, it’s under the round black plastic piece in the centre.
There is a thread here on cleaning and replacing the Oring
Well here is a run through for you,
Remove the cap,try blowing gently through the black centre piece.
If you can’t that’s good,try sucking,you should hear a click and draw air in.
That’s the one way valve working as it should,if you can blow through it a thorough clean is required.
The other possibility is fuel getting past the Oring
you can see it in the next picture
I use a 15x2 Oring and silicone grease here
the valve does come apart and has 3 parts
the clear disc is the valve itself
Yes the valve levers out,the top cap may come off as you do this,it did on one of mine.
I took the clear disc out and used a seal pick through the centre hole to pull the body out of the cap
Like others, I am trying to fix my dried up gasket. I modeled one and printed it with TPU and it worked well but didn’t last due to the ethanol. Someone mentioned getting some made if they had the STL. I’ve attached some images.
I’m tempted to buy the VF750f Chinese cap and use its gasket but want to make sure I’m ordering the correct one. Can someone provide more information about them please?
I know this is an old thread, but I just wanted to thank the hive mind! Just replaced the fuel cap seal with one from a generic cap for the VF750/1000/1100 bought on eBay and it works great! Cleaned the collar and sliding barbs and lubricated with a dry PTFE and it’s now working great. It hardly needs any pressure on the key and the cap and I’m really happy with the result.
Cool. Just ordered one, looking forward to getting yet another thing working like it should! Thanks everyone.
…but it sounds like removing the lock mechanism requires prying the thin black metal skin off the top of the fuel cap. And that ruins it, I think, unless you have specialist tools? Like to change the lock cylinder, but I don’t think I can. :confused:
