After getting the VF1000FE back on the road the starter clutch was giving me trouble on first start. I pulled it apart and found one broken spring and the others a little suspect. No problem I thought, I have a low mileage Boldor one sitting there from the engine that gave me the heads. I noticed the timing lug (not sure what you call it) was a little longer but I thought I would give it a try anyway. Not good, bike started great but would not rev past 2500. OK so I built up one out of a mixture of the best parts and it is better but not great. I have now ordered some new springs from Honda which will be 6-8 weeks.
My question is… has anyone successfully reconditioned the starter clutch outer to ensure the rollers do their thing correctly? A gentle rub with an oil stone would be my go to but interested in anyone else’s experience.
As you can see I do everything I can to rebuild old parts, not just replace with new because it is easy.
