Ok as I’m nearing the end of my build I’ve got some stuff surplus…
Sidepanels- fantastic condition, no cracks or broken lugs- £50 each
Tail section- also great original condition, no cracks or damage £50
Bellypan- original white with Red V-FOUR decals, one small crack about 2cm to top right mounting hole, has been plastic welded but not painted -£50
Top Fairing- both sides and headlight surround- from a different bike, have been damaged and repaired, very solid but will need finishing and painting. -£50
Also (open to offers…)
set of clocks, 43000miles- I’ve cut the loom as I needed it to splice on my aftermarket set.
Clock surround
swingarm and chain guide block + suspension linkage
chain guard
-rear caliper and bracket, lovely condition
Sorry work plans have changed I still want the belly pan but not sure when I’m going to get over to collect
If you get a buyer before then sell it I will let you know next time I’m in the area to see if you still have it
