Hi there, I’m trying to find engine bearings for my 1984 VF1000f2, I’m looking for mains and con rod bearings at 10 thousand / .25 undersized.
I’m hoping someone can help.
Hi,bearings were never produced in oversizes,only 3 grades of standard bearings are available.
Is the crank damaged?
regards Bif
Hi there, thanks for reaching out, the crank has scoring marks on it, the engine builder told me that if I do manage to find shells he will machine the crank to match the bearings.
First off,where in the world are you?
I did find some big end bearings that only required honing the con rod to fit in oversize Can’t remember off hand the numbers but I can check that out.
Main bearings are no luck.
If you are UK based I know of a good crank from a low miles engine complete with con rods and shells
As our Bif mentions, the bearings are colour coded/matched to the crankcases and crankshaft/rods….
Just curious, the “F2” is an 85 model, not ‘84.
