Wheel conversion kit
Hi Team
I have decided to go down the CBR600F2 wheel conversion path on my 85R
Is there anyone that does a kit with all the spacers etc? I don’t know any local machine shops and am hoping someone makes these up!
Jamie Daugherty was doing this several years ago…he’s in the US though…not sure if he’s still doing them. He mainly does shock absorbers these days…but you never know, drop him an email or call. He’s very aproachable and knows his shite.
Teambif have had kits made up,mainly for the F model as below
The front of the R is fairly straightforward,the rear not so much as the standard calliper won’t fit with the larger hub on the F2/3 wheel.
I have used a 900 fireblade in my R and modified the swingarm to accept a 600f3 caliper bracket.This meant welding a locating peg to the inside of the swingarm,a job that was outsourced due to it being beyond my abilities.
We are at present working on an underslung caliper which will use the original torque arm,a 240mm rear disc and a Tokico opposed piston caliper.
We are based in the UK and Germany but can ship parts worldwide when required.
The wheel swap also works well with our front brake upgrade,310 discs and 4 pot calipers for greatly improved breaking performance
Thanks Brett
I reached out about a week or so to him, but not sure if he received my message or if he is still around, haven’t heard anything but may in the next week or so (hopefully)
Cheers Dave
Thanks Big
So do you do kits of the spacers for F&R 600F2 wheel swap?
We have them made,kits complete with oil seals,spacers and bearings where needed.Parts we require to modify are f2/3 sprocket carrier,VF Speedo drive and a rear brake bracket from a cbr600 f1.This is for an F,we are currently working on the R kit
Thanks Bif
I was under the impression (perhaps mistakenly) that if I use CBR600F2 wheels, the front is basically spacers and speedo gearbox adjustment… and that the rear could be facilitated by using a VF500 sprocket carrier and the CB aero caliper mount.
Do can I purchase these spacers from you if I’m correct?
Hi Dave,
I had someone here in Germany doing a “kit” for me. For the front we used the VF1000R axle and the Vf1000R speedo drive with the original brakes. It required new wheel bearings (different diameter of the the axle.) new spacer inside the wheel. The size of the speedo has also to be a little bit reduced and you need a new spacer on the other side and new seals.
On the rear it was the PC25 brake caliper with the holder. He welded a bolt to have the torque blocked from the swing arm. and you need two spacers on each side. I hade 160/60-17 wheels and needed to cut the chain cover a little bit.
Axel
I can do the front no problem,I will need your Speedo drive to modify.
Thanks Big, that’s great. What country are you in?
I’m thinking if I can buy one and get it shipped directly to you…
Sorry phone keeps on auto correcting BIF
I’m in Scotland
Thanks Bif
Lets e mail so your details are private
I’m on Dave.mohr59@gmail.com
