I agree with your observations there, Bif.
The VF750F is a very different animal, it’s a lot lighter for one, and an awful lot smaller.
A Honda Varadero 125 is physically bigger, for a start.
It feels like a far smaller bike, and that very much dictates how you ride it.
You still get the “slightly nervous” feeling with the small front wheel but you very quickly get used to the fast tuck in at slow speeds. It’s very predictable, and very easy to adapt to, especially once you start goosing around with the antidive, preload and pressures.
It handles exceptionally well for a 30+ year old motorcycle.
Handing wise, the VF500F2 absolutely nails it, its completely confidence inspiring and handles neutrally despite the 16" front. It encourages you to throw it into corners and it copes very capably with anything i’ve thrown at it so far.
Apparently (I would not know) if you change the rubber sizes in any way it borks the handling completely.
Something i am very loathe to do!
Obviously the riding position leaves quite a bit to be desired on long distances.
I’ll add observations on the others.
VF1100C. Handles surprisingly well for something the length of a goldwing. It’s quite neutral, but you have to adopt the cruiser approach of constant speed corners, and constant lean angle all the way through otherwise the bike feels unsettled and wants to oversteer or understeer.
Under power it squirms a bit and will lift the front wheel easily with no clutch up to 3rd with little effort.  The thing that ruins it is the rear shocks are far too hard, and don’t feel “soft” enough to absorb bumps comfortably. I’m looking at resolving this currently.
Other than that, its a cruiser thats fast and handles reasonably well, which surprises a lot of much newer bikes.
VF400…Very much the same as the 500, but the riding position is far more upright and more akin to an adventure tourer. Great little bike, very easy to ride, very predictable and the inboard disks are surprisingly good despite all the bad things said about them.
Comfortable for 1 1/2 hrs in the saddle too, i could ride that thing all day.
Hope this helps someone.
