hi guys- my rear tyre needs replacing and I’ve got a spare 160/80 with good tread out back.. has anyone put this width on a standard VF1000fe wheel? and if so, how did it handle?? cheers
A 150 70 17 is as far as you should go. It is within the recognised sizze differential. The 160 80 would give a horrible profile .
yes I hear what you’re saying- but I’ll be riding on the road at 100kph - no where nr 160mph on a track.. so am interested if anyone has done it and their experience? - I have a 150 but I’ll have to take it off a wheel first- but this 160 is ready 2 go–
Hi Trev,
When i did my first cbr600f2 wheel conversion (4.5 inch rim) many years ago, to run a 160 tyre i had to alter the brake torque arm as the tyre rubbed on it.. hope this helps
Dear Trev,
for me it’s a fact that the handling of these old bikes with the smaller original tyres is better than with wider tyres. I did the switch to a 5,0 inch rim and a 160/60 only to have more options to use actual tyres. The handling is not better.
Because you want to use the original rim and the fact, that handling is a subjective feeling, you have to spend the 20 bucks for mounting this tire.
thanks Pete- gd to know.. did u grind a nick in it or what? -I’m dead keen to put on this gsx750 wheel I have (with the 150 tyre already on it) but have no time 4 faffing around 2 make it fit at the mo, so it’s on the back burner..
Dear infinytumb, I’m really just being cheap here as I have the 160 already and was keen 2 know if anyone had chanced it before.. it’ll cost me nothing but time as I’ll change it myself, but real life experience is better than time lost doing an experiment gone wrong- I could just sell it and buy a 140 I suppose (ie more faffing around- ha!)
