Hi and thanks for having me in the forum! I recently purchased an 86 RF for restoration. I’m digging into the wiring now and have found it got a little butchered. The fan tails have 2 pin plug tails on each one but there is no mating connectors to plug them into. Upon further inspection it appears that someone has cross wired a few things. The lower radiator has a thermal switch with a one wire connection and a separete wire going to ground (both are cut). I’ve searched thru the resources here but I can’t find anything showing where the fans plug in or what wires they should be connected too. Any help is appreciated!
Thanks, Dave C.
