Gooday VF brains trust,
I have painted tank and panels, and decals ready to go. Looking at my originals, it looks like a coat of clear over the top?
I bought a mostly restored bike in bits, so not sure of type of paint, was painted about 2005, so its quite dry and hard now!!!
Anyway, Im assuming that I apply the decals then a coat of clear, any expert recommendations- Im in Oztraya so some Brit paints may not be available.
Im not much of a painter, Im considering getting a tradesman apply the decals and finish the clear. The painted parts have a very high quality finish, I don`t want to stuff great paint up with my dribbly runs if it is too difficult?
Hi yes you are correct enough sure the paint is thoroughly clean use panel wipe or soapy water, then thoroughly dry the parts, use a good apply the decals and wear latex gloves as the grease from your fingers can cause reactions then apply the 2k laqueur, mixed to the correct ratio with activator, and I add about 10% thinners to aid putting it on, use a good hvlp gun and ensure it as a water filter fitted and a pressure gauge, I use a 1.4 needle in the gun and apply about 3 to 4 coats which will give it a good shine leave for about 24 hours and buff with fine cutting compound, failing that get a professional to do it, the main thing is to remember mixing correctly and not putting it on to heavy I normally leave about 30 minutes between coats depending on temperature, probably alot warmer where you are
