Hi brought these brake line thinking I’ll get rid of the splitter… any thoughts on this before I fit them Thanks Sean
I have braided lines on my RE, still using the splitter though…just be careful when going to full left steering lock…the new fitting may hit the fuse cover.
Ok thanks the heads up ![]()
I see what you mean smithy… lines close to the fuses…. Reconditioned forks and calipers… getting there now just the rad to get repaired.
I just ran a single line down to the splitter, much more clearance at the top and “just” misses the fuse cover, had to tilt the brake master cyl back a mm or so to clear it.
To be honest I ordered the race line ones not knowing I had to double up at the brake end… should have ordered the standard set up now I know… might re order and try and sell these… not bled the brakes yet
