Hi Bart,should have one in the store,I will have a look tomorrow.
From memory the follower needs the shaft removed and then turned a bit before it comes out,never actually tried it with the cam in place
Downer Bart. … I seem to remember trying to remove a rocker arm with the cam in position… Unfortunately it wouldn’t come out from under the cam…
I do hope it’s a front rocker arm that needs removing as some of the rear ones can’t be removed with the engine in the frame…
Yep… one of the end bolts that holds the cam caps down goes across the end of the rocker arm shaft, you will have to remember that when you reassemble, the shaft has a notch in the end that needs to be at 90 degrees to the head… but even with the rocker arm shaft removed the rocker won’t come out from under the cam… you may get away with loosening the cam caps and lifting the cam slightly…
Got the follower shaft out but as suspected the follower will not come out with the camshaft in place. I’m worried that if I just loosen the caps the tension in the cam chain my pull the camshaft in and end up in a right pickle. I can’t do much till I have a new follower so will sleep on it.
The good news is the cams look pretty good though.
The other thing of concern is the oil strainer being clear.
