Hi there,
I know it’s annoying but I need to finally know which cams of the VF 1000 model are compatible. I know that the cams from the geardrive R-models do not fit to the F-models, but are any chaindriven camset exchangeable? Same question for the rocker-arms!!
hi hans, looking at the photo’s on your other posting i would say that your bike engine is a 1984 FE model, the later 1985 vf1000 ff cams are longer and will not fit, the rocker arms are also different.
the 1984 vf1000RE cams are gear driven and will not fit but the rocker arms may do… some one with a RE would be able to advise better about these.
