Gents
Looking for tank cock assy. to buy…
Thanks
Gents
Thanks
In the UK fowlers of Bristol have them but not cheap at £52.19 or cmsnl for €35.50 but postage from Holland isn’t as cheap so I usually try to get everything I need in one delivery. I would recommend getting a new one as even with a new gasket old ones can leak from the internal o ring.
G
Cheers Gaz
Thanks for tips
Thanks for the link PointerX
I would repair it. The cock assy is also over 30 years old. You can drill out the rivets, disassemble and replace the rubber. Cutting thread and putting evering together.
UK:
Honda VF1000FE/F/F2F 84-86 fuel tap internal seal kit (nrp-carbs.co.uk)
US:
60-1221 | All Balls Racing
Axel
Cheers Axel
Think I will give it a go before spending the money…
I wouldn’t drill the hole “free hand”. Use vertical drill and bench vice (hope the words from my dic are fitting).
Understood perfectly
Hey there! Did you get the tank cock?
Hej Langvatn
Yes as per @garyb suggestion. Found Fowlers of Bristol very helpful and delivery was quick. Cockpit valve came complete with small gasket (16958-MB4-005)
Highly recommended
