The coils on my 84 1000F(USA) appear to be cracked. Previous owner tried to repair them with a strip of RTV. Any recommendations on replacements? Can’t seem to find any direct new replacements, and used options are $$$. I’d love to do a COP conversion one day but for now I’d just like a semi affordable quick swap option. Any input is greatly appreciated!
The coil is common across the VF range so this one on eBay would suit,item no.394047298340
I used these coils…along with new leads, plugs and plug caps. Also fitted some new igniter boxes from Carmo…ignition is much improved over the stock setup.
They look pretty slick. What brand? What plugs are you running as well, I should probably replace those while I’m at it.
Does this mean a Sabre or Magna coil would work?
@intercept3d_v4 I’m running stock NGK plugs, nothing special. The coils are from an Aussie mob “Tri-Spark”… https://www.trispark.com.au/dual-output-high-performance-coil-dyna-style
Same part number as Sabre and magna
30510MB0701
