Gooday VF Gurus, a mate is rebuilding an 84 FE, and the motor is dodgy, with fried cams and head journals, and possibly other problems.
He has the possibility of buying a 85 FF motor but needs to know that it will fit into the frame.
Questions are:
are the FE and FF frames identical?
will the FF motor with wider cams fit into the FE frame?
I`ve seen frames cut to fit the bigger heads, from memory it was a later R motor going into an FE.
I have an FE with OK bottom end. I have the opportunity to buy an FF engine with good heads and cams but unknown bottom end. Will the FF heads fit on the FE engine?
