I have mentioned previously that I am no fan of the air fork arrangement, but since I have them and want them to work properly, I was wondering if anyone has fitted a low pressure gauge to show how much air pressure is actually in them?
My thoughts are either a tee adapter on the top of the left fork leg that could run to a gauge, or a more tidy solution could be a tee in the balance pipe that could run straight up to a gauge that could be fitted to the dash panel?
A 37mm (inch and a half) diameter, 0-15 psi gauge would be ideal, and can be had for around $25 like this one, http://www.ebay.com.au/itm/1-1-2-0-15psi-Fuel-Pressure-Gauge-Non-Liquid-/370948838463?pt=AU_Car_Parts_Accessories&hash=item565e46143f&_uhb=1
What do you guys think, would this be a worthwhile modification?
Is there a huge difference in how the bike behaves with no psi vs 6 psi? I haven’t done enough kms on mine to know yet.
Tony
