Fuel pump for a VF1000R 1984
Hi looking for a fuel pump for the VF1000R if anyone can help. Thank you Sean.
Hold that thought.. might have repaired it.. I opened the point contacts very slightly and cleaned the contacts.. have a nice noise combing from it​:blush:
Just get rid of it altogether and run gravity feed…I’ve been running gravity feed on all the VF’s I’ve owned for many years without issue.
I Tried running no fuel pump and found harder starting and fuel starvation when it was getting close to needing reserve. That was with an FF with larger diameter fuel outlet pipe, and carefully routed lines.
