As many know I’ve been slowly rebuilding a vf1000 well times came where all my projects are on the side now
The fe needs to go
Frames been painted front brake are perfect it’s got two neta rear cans need paint sorted the collector box needs a pipe welded for the pipes on the back
Front mudguard paint job is ok I have rest off the plastics in good Nic
Dash board is in amazing condition working fuel pump carbs will need looked at if I can get it running before it goes i will fill coolant system new clutch line it’s got full braided lines the wheels are not perfect they are cheap nasty ones that are on bike to get it rolling I have the originals that need powder coated and bearings and tyres it needs a fuel tank needs a rear brake
Has a f2 shock on the back
There’s so much been done to it had cylinder heads off to do valves as it had no compression no valves done has compression but I cannot garuntee engine will run I’ve not tried
Wiring loom needs attention
She has so much potential I just don’t have time or money to finish it off I’ll put it up for 600 but if someone’s interested I will take offers collection will be from Dumfries Scotland
I’ll get some better photos today or tomorrow
