every where i call. nope this is discontinued its obsolete. all i need is a damn coil wire!
This is part of the joy of the VF range,but things as generic as HT lead can be purchased from most parts suppliers.
NGK do a range of plug caps in black as well as red so it’s fairly easy to keep the standard look
so ngk makes it? do you have the part number by any chance?
You want something like these…
HT lead, red per meter.
HT lead black, per meter.
Hope that helps.
you will get a grin when its running well worth the wait
i had it running great and then it started running like the choke was on like bogging out at high rpms sputtering and stuff. so i pulled one of the wires and it broke :’( :’(
also i need the wire and cap
as one piece i didnt think you could put them together
Follow the two links i posted earlier.
The leads “screw” into the coil, and also into the plug cap. Well worth replacing the leads and caps as a full set.
