Hi Fellas, has anyone ever lowered a VF1000?
Thanks
Thanks
Nope ! ! !
How would you?? any idea’s??
Hi,the rear end is easy enough,just adapt Jamie Daugherty’s idea for raising the rear end.Details at www.daughtertymotorsports.com.
You can’t push the forks up through the top yoke due to the air link pipe.So you could fit a spacer on top of the rebound spring say 1" and remove 1" from the spacer above the spring.Anyone see a problem with idea?
Regards BIF
