hi there, i need to replace the orings for my shift arm/shaft and the clutch lifter rod that are under the left crankcase cover - anyone?
thanks!
thanks!
Hi Lepto,you will need oil seal part number 91204-mb0-003 for gear change shaft and 91209-mb0-003 for the clutch.If you have a bearing supplier nearby ask for a 8x25x8 oilseal for the change shaft and 8x18x5 for your clutch.Regards BIF
