Right here we go i am sitting on my f2f the tank is off and ime looking at the coils the left hand coil feeds the rear two cylinders, does the plug lead coming from the left of the coil go to the left hand cylinder,? Or the right,help me out lads ime confused.com[:I][:I]
it does on my fe, i would assume its the same for the f2f
Hi Fallingspark
It doesn’t matter how you connect the plug leads to the cils, as long as the rear are the rear, and fronts to the fronts. It is only one coil, receiving signal from one pickup, and feeding 2 cylinders. So you just place the plug leads as you want’s too.
ahhhhhhh now that makes sense,thanks lads[^]
