Rear lift point using bar
Looking to put a bar through my RE rear axle to use as lifting points for lift stand. Looks like 8mm bar will fit.
Can anyone let me know if they have done this and what they used.
I’m interest also, as, my axle bolt is solid.
Yours should be hollow and you can then insert a rod through it for lift points.
plenty of thro axle bobbin kits on ebay that use 8mm threaded bar.
They look fine,I still prefer to use a paddock stand with cups to lift by the swing arm so I can remove the wheel
