The short hose that connects to the thermostat housing - part no. 19536-MB6-000. Any source for buying this as a single item? If not then will check out similar diameter hoses at my local parts store and cut to length.
I’ve been replacing the hoses with silicone ones,plenty on ebay but a local supplier should be able to do you a straight bit of 19mm id radiator hose
This was cracked on my bike when I bought it. I was able to find a replacement from Supercheap Auto that just needed a cut. From memory it had two bends in it. Found it in there big pile of heater hoses they have.
That’s exactly what I did. Rummaged around at Supercheap and found the right diameter hose and cut it to length. No leaks now.![]()
