hi all,
does anyone know if the rubber hose that goes between the rear brake master cylinder and the plastic reservoir,
is just large diameter petrol pipe, or does it have to be a different type due to it being in contact with brake fluid?
You’re probably OK using any hose. I’ve used normal motion pro fuel line before and have had no problems.
hi freelance,
thanks the info.
