Hi All I need to replace seat lock anyone know how to remove the bolts/pins
Those are shear bolts,you could try slotting them to fit a large flat screwdriver but a pair of molegrips has always worked for me
Thanks, molegrips worked fine
Why are you changing the lock?
If it’s just for the key,the number is on the back of the lock casing
The barrel was broken so needed to remove, i took it in to my locksmith and he has fixed he told me their was no need to remove the pins as he removed the barrel from the front, Ah well i learned something anyway so all good.
