Stand
Need front paddock stand for vf1000 Bol d or , an idear for the best one
I use one very similar to item 400926866152 on eBay.
It lifts from under the bottom yoke with a pin that fits into the steering stem.
You will need a 24mm pin for a VF,this was not included in the selection of pins that came with mine so it may be worth specifically asking for one.
With this you can remove the forks as well as the wheel.
