Hello again… temp gauge is not working, I know there is a sensor on the thermostat housing, is there a way I can test the sensor before I fork out £50 on a new sensor… thanks again Sean
Pop the wire off, ground the terminal to the housing somewhere and turn the ignition on, if the guage goes to high/full temp, the guage is ok, you can get temp sensors quite cheap off fleabay, I have one on mine and it works fine… Honda Vf1000r Temperature Sensor for sale | eBay
Again thankyou ![]()
