My 1000R ticks once it warms up after about 5 mins idling, goes away over 3000rpms only audible at idle. The noise seems to be coming from between the V’s? its only a light ticking noise and is definately not coming from the top end?
Any thoughts or anyone had anything similar?
Ari, might be the same issue I have! Certainly sounds similar. Whereabouts in NZ are you? We could compare ticks!! I’m in Auckland
I’m in WElly but travel to Auck fortnightly
I assume you ride up, when in Auckland? If you want to touch base and compare ticking (!) PM me on the Kiwibiker site, same name “Diggers” . Cheers
