Hi guys,
probably anybody out there can help me.
I´ve found oil leaking out of the valve cover gasket of the front cylinders of my SC16 (f). It was quite a bit and since I have nothing else to do, i´ve decided to take the cover off, check the valve clearances and renew the gasket…easier said than done, it seems as if they are not available anymore. I need the one with semicircular mouldings for the 85 model. Any idea where I can get these?
The oil leaks between the cylinder head and the gasket, the surface of the head is clean, so there was no extra sealant applied. The gasket itself looks quite good, the question is if you would recommend to apply sealant between the gasket and the surface of the head.
Thanks and best wishes!
Joe (who intended to write that in the “In the shed” category…)
