Vf1000 Oil pipe up or down
Hi all, just chasing opinions on the top oil h pattern pipe on the vf1000 interceptor, the Honda manual says the small legs to point toward the exhaust outlets, when I took the cover off one was the other way around, does it matter?
Honda must have their reasons,it’s not a big job to swap round so I probably would
Yes, thanks bif, obviously previous owners attention to detail not quite there, nearly finished the engine rebuild, I see the timing issue has been disscused to death, but I think I’m with you as per the Honda manual, both marks pointing up and all lines across the heads on T13, not much other mention of the front cylinder apart from that, I’ll post some pictures shortly
