Hello everyone, I had an unfortunate incident this past summer and now I’m piecing out my VF1K. I have a list of some of the larger parts which I’ll post below, if you need something specific please email or message me, I’m trying to get everything cleared out before my wife strangles me! Thanks!
Handlebar controls
Rear Fairing
Air Box|Includes air cleaner
Intake Boots-New Spring of 2018
Grab Rails
Tool Box-No Cover
Fuel Tank-Dented But No Leaks
Carbs-Rebuild Spring Of 2018
Ignition Coils(CBR COP Conversion)-Includes Fans
Fuel Level Sending unit
Left Handle Bar
Left Front brake Caliper
Right Front Brake Caliper
Rear brake caliper
Clutch Master Cylinder-Some damage on Front Corner
Front Brake Master Cylinder-Bent Handle
Rear Brake Master Cylinder
Exhaust-Repaired leaks
Spark Boxes
Rear Shock-Includes Side Rails
Front Rim
Rear Rim
Upper Radiator
Lower Radiator
Head Light
Seat
Voltage Regulator
Wiring Harness-Main Loom only
Coolant Hoses
Rear Inner Fender-includes licence plate light/bracket
Front Fender|includes fork brace
Front Fairing-damaged
Tail Light|Damaged wire but works
Ignition switch/gas Cap/ seat lock
Swing Arm-Includes linkages
Engine-43,000 miles, drill and tap oil mod
If you don’t see what you need please ask, I may still have it. Also, I cant seem to upload pictures so please contact me for photos of the Item you are interested in, Thanks!!
Hey Jason,
Do you have good left & right handlebar switches?
thanks,
Walter
Yes, I have both switch assemblies. Everything works but the lettering is faded.
Do happen to have a starter, and is there a possibility of getting some pictures of the fuel tank(inside/ out)
Hi Jason, I need the rubber isolators that helps to hold the fairing pieces on each side of the windshield, if you still have them.
Do you still have the carbs ?
HI,i may be interested in the lower radiator and fans,also the intake boots,and gas cap,
