VF1000F2 crank bearings
Keith, I cant find the info, I got it from a zzr1400 abs (o6) workshop manual, think I down loaded it off ebay for a few quid, all the info will be in there,
Seem to remember that it was kwak conrod bearings were same size as vf1000 main bearings, as with all bikes there will he 3 size variations,
Its the con rod bearings that I need. It would be nice to see if I could find shells for the mains as well, but at this point Ill take what I can get. Ill start posting some pictures once I get past this first big hurdle which is the shells. Thanks.
Con rod shells are still available although you have to search for them.
The FF/2 model used shells peculiar to that model in the rear rods,however the earlier model shells work just as well.
Forger the colour codes and go by the grades A B and C
That lets you use shells with the MB6 MB4 and MJ4 codes.
They pop up regularly on eBay in the US as well as in Germany and France
seriously?? Ive been looking for a 1-1/2 years and only came up with two bearings…
what are the letters on the crank and the numbers on the rods then we can lend a hand
