Hey fellow VF enthusiasts!
A while back, I picked up a 1984 VF1000FE project bike that wasn’t running. The previous owner had done quite a bit of restoration work over the years but couldn’t get it to run cleanly past 3000 rpm.
Turns out, he swapped the engine for a VF1000F2 Bol d’Or (1985), but kept the original FE carbs. After some research, I discovered that the starter clutch also needed to be from an FE to match the ignition system properly. Swapped that in, and now the bike fires up and runs great—except for one thing…
The idle is too low, and the engine stalls the moment I drop it into gear.
I’ve been trying to adjust the idle but had a hard time even finding the idle stop adjuster knob. So here’s my question:
On the FE carbs (1984), which side of the bike is the idle adjuster knob supposed to be accessed from?
In my current setup, the right side is completely blocked off by the F2 cooling pipes and thermostat housing. I’ve seen that the F2 carbs have a knob on the left side for easy access, wish I had that!
Is there a trick or special tool for adjusting the FE carbs with the F2 engine setup? Or maybe a creative workaround someone’s figured out?
Cheers!
