Does anyone know if the Vf1000R 1984-86 pulse gens will fit my 1984 vf1000fe ?
I have seen some on ebay
none available new.
thanks
The pickups are the same for all 1000s as well as the 750F,the only difference is the wiring on the later models includes a connector for the temperature sensor on the thermostat housing.Your FE doesn’t use it so it can be removed
No,that’s the oil pressure switch,they all have that on the multi plug
Ok just checking
thanks for your info bif
