Temp guage reading goes down when i rev engine any ideas
If your coolant level is low,when the revs rise the coolant can drop below the temperature sensor.
The gauge will read cooler as the sensor is out of the coolant
Found the problem i knocked the bullet connector off the temp sender changeing the spark plug it was only just touching the sender
