Hi, I’m after some help with the correct way to remove the seat and surrounding fairing from a VF1000R without breaking any tabs or lugs. I’ve removed the screws on the fairing below the seat and removed the black mesh covers yet I still can’t see anything else that need to undone. Is it as simple as pulling the fairing away from the frame? I don’t want to force it in case I break something.
Hi Tim,just forward of the indicator mount there is a hole in the black plastic above which is a shouldered dome nut.Undo both of these and the rear of the unit can lift and then be pulled back to release from front fixing.Regards BIF
