Better to question twice than make a mistake once,yes 10mm off the CBR sprocket carrier,once the studs have been removed.Although the rear caliper from the VF will fit the CBR bracket I would recommend using the CBR caliper or at a push the front right from the VF.Having test ridden mine,I found the rear had run out of travel on the slide pin and locked itself on DOH
Now rebuilt with a CBR caliper
regards Bif
